carb help for 86 15hp evinrude
kkbraatz
I'm in the process of doing a carb kit when I discovered a couple of problems. First the top of my carb has a piece cracked and I was wondering where to get a replacement, it is the black hard plastic part on the opposite side of the float side. The other issue is the likely carb problem I'm having, there is a little hose inside the carb that connects inside the float and it was in two pieces. I can't find where to buy it or what it is called. This little motor is testing my patience. Thanks in advance for your assistance.
Re: carb help for 86 15hp evinrude
i have done several of those carbs, and do not remember any hose inside the bowl area. a picture of you carb would help, especially the plastic piece. the only plastic in can remember is the Cam follower and the air silencer.
kkbraatz
I'm a dork it is a 89 my boat is 86. I found the part it is the breather tube, and I believe it comes in the 89 carb kit just not the 86 that I ordered from iboats, I'm such a rookie.
the other part is the carb cover and it looks like I can get one from evinrude, not cheap, but that is boating.
Thanks rick that link was key to my soon to be sucess.
Rick.
http://www.sschapterpsa.com/ramblings/OMC/OMC info.htm
Stuff happens. Here is a link (you indicated you like links) that I consider a must read for any 9.9 or 15 owners who want to learn about there motors. He does talk in it about the plastic carb. covers and perhaps how to avoid them. Enjoy, Rick.
