Re: clear gel in carbs and jets
appreciate the responses guys. I think I am going to buy two small portables and stick em in the back of the boat and run it off those til the late fall when I will take the original gas tank out. Its under the console and thats not a job I feel like doing right now, wasted enough fishing time cause of my stupidity. Let me ask one more ?. I winterized the engine with my buddy and I had at most a few gallons left in my tank last fall and being it was my first year owning a boat I asked my buddy if it was necessary to treat the gas and he said not to worry about it, just to fill it up come springtime. If I had put stabil or seafoam in the tank prior to the winter would that have prevented the water separation?
Stabil for sure not. SeaFoam, probably not. Stabil deals with polymerization, or the penchant for gas to form varnishes over time. SeaFoam is mostly alcohol, with a witches brew of very efective exotic solvents.
The problem is water in the tank, and bacteria growing in the water. The water, and it's source (pourly installed vent, fuel source, condensation) is the problem.
I have a bass boat, and the highest spot I can put the fuel tank vent is only about 8 inches off the lake. I have a way to put my boat and trailer on a sidehill and get a siphon hose into the low spot. I do that a couple of times a year and pull off a quart or 2 of whatever is in that low spot just to forstall trouble. That and a fuel separator keep me going smoothly.
When I got the boat, I was dealing with the same chit you have to deal with.
hope it helps
John
