Carbon or Not
115johnson78
I have a Johnson 115hp. I compression tested two cylinders on the port side were at 100psi, the star side bottom is 70psi and the top is 40 psi. Runs rough at idle but will wot at 5000 rpms.
another todd
Re: Carbon or Not
May be a head gasket leaking between the two cylinders. Could also be stuck, carboned up rings, or worn out rings.
Re: Carbon or Not
A decarb is not going to solve that problem. time to pull the cylinder head and investigate. may be a simple as a gasket, may be time for a rebuild. a $20 gasket will tell the story. then you can decide that the gasket fixed it, or to rebuild, or to run it till it completely dies.
115johnson78
Re: Carbon or Not
Thats what I was thinking but im not a pro. Thanks for all the help and info.
What type of sealant for the new gasket?
