Part number cross reference
bluestng
I finally fgured out what is wrong with my powerhead. The exhaust baffle is bad with a crack and big hole. It is part number 314849, it seems impossible to find one but I am able to locate some from newer years. They look the same but with a different part number. My outboard is a 69 evinrude 85 hp. Would they be compatable? Thanks
Benny1963
Re: Part number cross reference
go to the brp site and hit diagrams and you can check what will change out with yours
bankerjohn
That part fits:
1969 115983E 1969 POWERHEAD GROUP
1969 115983S 1969 POWERHEAD GROUP
1969 115ESL69E 1969 POWERHEAD GROUP
1969 115ESL69S 1969 POWERHEAD GROUP
1969 85993E 1969 POWERHEAD GROUP
1969 85993M 1969 POWERHEAD GROUP
1969 85993S 1969 POWERHEAD GROUP
1969 85ESL69E 1969 POWERHEAD GROUP ELECTRIC SHIFT
1969 85ESL69M 1969 POWERHEAD GROUP ELECTRIC SHIFT
1969 85ESL69S 1969 POWERHEAD GROUP ELECTRIC SHIFT
1970 115083D 1970 POWERHEAD GROUP
1970 115ESL70D 1970 POWERHEAD GROUP
1970 85093B 1970 POWERHEAD GROUP
1970 85093D 1970 POWERHEAD GROUP
1970 85ESL70B 1970 POWERHEAD GROUP ELECTRIC SHIFT
1970 85ESL70D 1970 POWERHEAD GROUP ELECTRIC SHIFT
1971 100193A 1971 CYLINDER & CRANKCASE
1971 100193C 1971 CYLINDER & CRANKCASE
1971 100ESL71A 1971 CYLINDER & CRANKCASE
1971 100ESL71C 1971 CYLINDER & CRANKCASE
1971 125183C 1971 CYLINDER & CRANKCASE
1971 125ESL71C 1971 CYLINDER & CRANKCASE
1971 85193A 1971 CYLINDER & CRANKCASE
1971 85193H 1971 CYLINDER & CRANKCASE
1971 85ESL71A 1971 CYLINDER & CRANKCASE
1971 85ESL71H 1971 CYLINDER & CRANKCASE
1972 100293R 1972 CYLINDER & CRANKCASE
1972 100ESL72R 1972 CYLINDER & CRANKCASE
1972 125283R 1972 CYLINDER & CRANKCASE
1972 125ESL72R 1972 CYLINDER & CRANKCASE
1972 85293R 1972 CYLINDER & CRANKCASE
1972 85ESL72R 1972 CYLINDER & CRANKCASE
bluestng
Thanks, how did you lok that up that quick? So if it looks the same it should fit?
tx1961whaler
jay_merrill
www.shop.evinrude.com lists this part as "dealer direct." Aong other things, that means that places like sea-way marine will not have it. If they don't have it, you can bet the part is going to be hard to track down.
If there is any possibility of welding the part and reusing it, you may need to consider that option. You will have to seek out a very skilled welding shop, however, so that the part is not warped durign repair.
bluestng
I found one on ebay but however it looks the same, but it has a different part number.
