Re: I know this has been ask but I'm still not sure ? about using the radio with boat
I'm going to toss in here...
First off, running a radio for 20-30mins should have no effect on a marine deep cycle battery whatsoever! By design, they are intended to be used for a long slow draw (trolling motor anyone?)
I had run the radio in my previous boat all day long, (8hours?), and still start at the end of the day no problem! (was a 5.7L mercruiser).
If your battery is draining down that fast, it probably has a dead cell in it, and should be changed. You can take it to any local auto parts store, and have them do a draw test on it, (for free), and it will tell you what kind of shape its in.
If the battery is good, then you still have a few options:
one option:
You can also opt to get a battery monitor (any auto parts store, walmart, etc.), it plugs into a cig lighter power outlet, and lets you know the status of your battery, although it would probably take a few trial and errors to know when the engine won't crank compared to what shows on the monitor...
another:
Get one of those plug in solar thingys that slowly recharges the battery.. being out in the sun on a boat, it "should" keep ahead of the draw of the radio (but you would need to know the draw of your radio to be sure, if your radio draw in amps exceeds the output of the charger, it won't work), just plop it on the dash/sundeck/whatever, while anchored, and your good!
example:
http://www.batterystuff.com/solar-chargers/SE170.html
Lastly as mentioned, and the option I agree with most, and probably the
BEST option, get a second battery. On a boat your size, it most definitely has the space, and it was probably even a factory option to come with a dual battery setup... there are a couple ways you can do it,
1. install the second battery, and get one of the switchovers (big orange dial thingy that lets you swap between battery 1, battery 2, or both). You can use one all day, keep the other one ready to go, if batt #1 won't crank the engine, switch it, and you're good to go. or
2. second install option, is to simply plop the batteries in, and connect them in parallel, this keeps your 12v rating, but doubles your amp hours by drawing down both batteries at the same time. If you dont want to spend the money for the switchover (almost the cost of a marine battery). Diagram for connecting in parallel:
http://www.batterytender.com/includes/languages/english/resources/Connecting_Batteries_and_Chargers_in_Series_and_Parallel.pdf
Diagram starts on page 2.
Ideally having the switch over would be best, as you would maintain a completely fresh battery ready to switch to at any time.
Anyway hope that helps a bit! Good luck
