Boat is leaking
Cort424
My boat is taking on water when pulling a tub. It does not seem to be when docked. It just started doing it last weekend. Any ideas on a cause?
rbh
Re: Boat is leaking
inboard, outboard what make of motor and boat?
rob
Cort424
Re: Boat is leaking
Sorry it's an 18ft. Marada ski boat with a I/O v6 mercruiser and it's fiberglass. The boat mechanic looked it over and didn't see anything and said he has never heard of that.
CheapboatKev
Re: Boat is leaking
Possible that when pulling the tube..the load on the transom is causing some flexing? Opening a unseen crack when not under strain? Perhaps under the load you are leaking at the I/O housing?
How much water are we talking about?
Mark42
Re: Boat is leaking
Check for leaks where the tube is tied to the boat. Probably using transom eyes, so check them for being loose, or anything else the tube is tied to.​
Cort424
Re: Boat is leaking
It's filling all the way up into the floor of the boat in a matter of 15 to 20 minutes. The tube hooks on well above the water line. Is there any way to find this crack while the boats out of water?
