KaiBlaed
Thread starter- Joined
- Jul 18, 2009
- 28
2cyl 2 stroke. Magneto. I am having intermittent problems. I cleaned all the crud out of the carb, replaced the needle, float, and gasket. Cleaned everything out, its spotless now and all the tubes are cleared. I bought new spark plugs. Gapped them to .30. After all that the engine was trying to start, wasnt getting very good spark... Pulled the flywheel, cleaned off the points and adjusted them to .020. I had it running great one night, ran for about 20min. The next morning it wouldnt start and I wasnt getting spark to the top cylinder. Checked the points and one had widened, so I adjusted again. Then the engine runs but spits and sputters the whole time. So I adjusted the points again, and adjusted the high flow needle.... nothing ... The control box for the throttle wasnt working to open the engine all the way up after it was running so I adjusted the cable and then it ran great at higher rpms .... I idled it down too far and it died and now it will not even attempt to start. now I'm sometimes getting spark .. sometimes not .... I've adjusted everything over and over ... I get spark when testing it but it doesnt even try to start. Could there be something that is causing the engine to not start after it has warmed up?
