disturbthepeace
Thread starter- Joined
- Apr 10, 2009
- 8
Hey ya'l...
I have a 58 Johnson super sea horse 35hp that I have been using in the local bay for fishing.. Well I have noticed that it seems to load up at idle and not perform at all in open water. I have been trying to fix this for a while now and Im at my wits end on this one.. so far I have replaced:
Coils, points, wires, plugs, condensors, gap at .020
carb has been cleaned and blown out with compressed air, float is level with bowl. needles are set to 1 3/4 out and 3/4 for high speed.
compression is at 115psi and I have done a de-carb clean on the motor
it will stuart fine bt need alot of throttle to keep idle high enough to idle. if it's to low, it will sparaticly miss on both cylinders as if it was loading up with fuel.. I can putt around the harbor all day but as soon as it wants to plane out the motor cant take the load and seems to load up an run on one cylinder( i have disconnected the cut off switch on the side of the motor to rule that out)
when doing one of my head scratching sessions and looking over the motor I found something od with the throttle linkage
if you look at the pic the linkage bar is connected to the lower eye of the timing roller. this puts the throttle position at about 80% open
.. I looked and looked through my seloc manual and found one fuzzy picture that showed it hooked into the top hole.
this puts the throttle plate at the closed position and I thought to myself "BINGO" this must be it!
so I made a bushing and tried it out......
wouldnt even start
I can get it running if I put it in the lower hole but when I try to move the rod back to the top it wont even idle.. I made a little video for you your vewing pleasure:
http://www.youtube.com/watch?v=v3uCMeGBSbs
I can only imagine that the previous owner moved the linkage to fix a pe-existing problem, but what that is I dont know..
Please someone point me in the right direction, I would like to get back on the water...
wouldnt even start
