KRH1326
- Joined
- Sep 22, 2007
- 491
Hi All,
Found a whole new problem to work on.
I was running through rough chop, 2-3' chop , at approx 3100-3200 RPM. Out of the blue, I lost forward thrust, and the engine rev'd out to above 5000 RPM, and I instantly dropped throttle and slipped nuetral.
I poked around and couldn't find anything amiss. I hit forward and started to move. As, I tried to throttle up, I wasn't getting any more forward thrust, but RPMs started climbing freely. I completely shut down.
I ( with engine not running) slipped forward gear, went to prop and turned by hand. It locked up OK in one direction and turned the other way with what felt like spring resistance. Tried the same for Reverse. It locked up the other way and turned the other with the same kind of springlike resistance.
As far out as I was, and the fact that I had two of my small children with me, I decided to just put back to the bay, back to the harbor, back to mooring and get the kids on firm ground.
I was able to make it at 1000 RPM's and NO MORE. Any higher RPM resulted in climbing RPMs.
I understand how the Electric shift works, and have been EXTREMELY anal about only shifting below 500-600 RPMs. I have not strained this system whatsoever.
If I wrecked the shifting mechanism, I don't know why I still had forward and reverse at and below 1000 rpm. Is there a clutch incorporated in the prop? I know that my little outboards always had shear pins, do these large props on upper HP drives have some sort of protection?
I have never had any type of electrical issue with this boat, and do not have issues with losing power, intermittant power or anything like that.
OK OMC guys, where do I start looking?
