Evinrude sportwin 9.5
smg215
Hello, could anyone ID the year of my evinrude? Sportwin 9.5 hp Model#: 9222M Serial#: J 016050. Also, the motor has been sitting for about 2-3 years so I would like to clean the carb and change the gear oil. Anyone have any pictures or can explain how to clean the carb, drain the float bowl, and change gear oil? Thanks.
Re: Evinrude sportwin 9.5
1972. manuals http://www.outboardbooks.com/index.cfm?fuseaction=models.main&year=1972&ID=108400
instructions: http://www.outboardbooks.com/index.cfm?fuseaction=models.main&year=1972&ID=108400
Carburetor Repair Kit, Part Number 382048 no aftermarket kit.
diagrams http://shop2.evinrude.com/ext/index.aspx?s1=bf6ad09c53cead335fcfd8a6471c0f7f
Changing lower unit oil
There are 2 straight slot screw on the starboard side of the lower unit. Top is vent plug, bottom, drain and fill plug. ( do not touch Phillips head screw).
Remove the bottom plug, put container under lower unit, now remove the vent plug, while the oil is draining, replace the seals on the plugs part # 311598, buy several of these, ( they are a one time use item)
Walmart and many places sell a little hand pump. To use to fill the unit, you insert the tube into the bottom hole, and pump till oil reaches the vent hole. Install the vent screw, then remove hose, install the drain-fill screw, clean up mess.
The screws can be hard to get out, do not mess up the head. You may need to employ an impact screw driver to break them loose.
smg215
This is excellent information. Thank you very much Tdaddy.
