Keel Rollers (Spool Roller) needed 5-1/2" Lenght 1/2" shaft Holscraw 1975
SMEYLINK
Looking for replacement Keel/Spool rollers for a trailer. Size is 5.5" x 1/2 ID I have this information from the original parts catalog, however company is no longer in business. Looking for my best option to replace. I can find 5" at the local store, 5-1/4 RP-504 Stoltz but are 5/8 shaft. Rollers on the trailer today are closer to 5-3/4" and the brackets are just shy of 6" wide. No room to upgrade brakets due to the trailer design w/o raising the boat 3-4 inch. I have found in AU 6" rollers I could cut down, but wanted to find something like this in the states if possible. Any help would be greatly appreciated.
Model of Trailer is Holscraw D-1250 I have replaced the gas shock absorbers and 34 years on the Keel Rollers is starting to show it's wear. Trailer centers well so I am thinking of using the 5" rolllers and seeing if they have any issue. 2 donuts of larger OD on each side as spacers would be nice going this route, but 3/8 width is not jumping out at me to purchase. I have access to a metal lathe, if buying raw material and machining the 3 rollers I need I am willing to do as well just would like to purchase to save my "free time" which is eaten up by 2 kids and enjoying the water.
wa_ssv197
Re: Keel Rollers (Spool Roller) needed 5-1/2" Lenght 1/2" shaft Holscraw 1975
Fisheries Supply
SMEYLINK
I sent help@fisheriessupply.com a email to see if they had the size needed. Didn't see it on the hyperlink. Thanks for the suggestion I will hopefully have a go / no go answer in a day or so.
