Hello this is my first post. I have reasearched the forums and have gained alot of information, but I am having trouble find the information I am looking for. My engine overheated and sized. I think after reading some of the posts my impeller pump went out. I have an OMC 400 190HP outdrive. I found an auto Ford 302 engine and I am swapping over all the marine rated parts and putting brass freeze plugs in it. When I removed the exhaust manifolds the port side almost had a hole in it from corrosion on the aft lug. The starboard side did not look that bad but I need to inspect it further. The boat has been in salt water most of the time. The guy I bought it from had it in the salt out of Westport WA and in Puget Sound. I have had it in the Sound about 4 times. I did not take it out much since I recently retired form the Air Force and was gone alot. I am trying to find at least the port side log style manifold and maybe a whole set. In my reasearch I know they do not make after market log style manifolds for my engine and I am not sure if there any conversion kits with the center risers will work on my engine. They are also very expensive. Any Help or information would be greatly appreciated. My wife wants the boat fixed and using is or sold. I would like to get it fixed, but I do not want to spend a foutune either.
If I had know about this site with the research I have done I am sure I would not have bought this boat in the first place.
