mattinglyt
Thread starter- Joined
- Jun 6, 2009
- 31
OK, I've checked just about everything that I can on my motor and it all seems to be checking out, except I cannot get it started. Only thing that comes to mind is when I removed the flywheel and the plate that the coils get to so I could move the plug wires, the mounting plate for it might not have gotten back into the exact spot.
Not sure if that's clear enough. When I lifted the plate that the coils mount too and took out the four mounting screws, does that plate that rotates have anything to do w/ timing of the engine? I thought I put it back together the way it came apart, but I could have gotten it a bolt hole or two off. There is multiple bolt holes and I just lined it up to the holes w/ the marks on it from the bolts.
If it is timing, how do I get it set correctly on this engine?
