1986 Evinrude 150 hp not starting Fuse Location ?
al r.
Help,I was working on my accessory panel and accidently hit the ignition switch with a wire . I now have no trim and when I turn the ignition switch nothing happens, I suspect I blew a fuse. My problem is I do not know the location of the fuse on the motor. I just got this motor & Boat and am very naive'. I truly apprciate any help.
Re: 1986 Evinrude 150 hp not starting Fuse Location ?
near starter solenoid, red inline fuse holder. has short 20 amp fuse. you can see one the the lower extreme right of this picture.
al r.
I cannot thank you enough you solved my issue.
al r.
Thanks so very much ! Problem solved !
