My engine flooded with oil last week because of a leak on the VRO pump. So every day when I can home from work I cracked the engine to burn off the oil with no water attached. It would just choke up and shut of in second or 2, I would do this about 2 times a day for the last 3 days maybe 4. Well yesterday it finally stayed on so I shut it off and connected the water to the engine to finish burning the oil out and there was not one drop of water coming out from the top of the engine where it shot it out. I have a new impeller since I was going to change out the pump this week anyway, My question is once the pump goes bad shouldn't it still pump put at least some water???? Because not one single drop was coming out with the water connected. Is there some thing else I should check??
Thank you,
Chris
Thank you,
Chris
