LiLGrady17
- Joined
- May 1, 2008
- 67
This is the first time I had the boat out this year. Did a bunch of work over that last two years on the engine, & was so looking forward to an 'un-eventfull' boating season..
Yeah RIGHT!
(new WP impeller, carbs rebuilt, new fuel line & ball, new starter, Seafoam decarb, timing checked -Joe Reeves Method, Link-N-Sink, new plugs, replaced lower unit oil, new batteries & a cable)
Launched the boat, started right up.. As we were headed out the creek, I noticed some more exhaust smoke than usual, but, figured, since I've been running the engine on the muffs so much, there was probably alot of oil caked in the exhaust housing.. Once I made the entrance, I throttled up, exhaust cleared to normal.... It hit 4500-5000 right away, we got up on plane. Then the engine started to surge, up to 54-5600, then drop off to 44-4500, then recover.. First thing I thought of was the old gas' ethenol absorbed some water over the winter & throttled back a bit. I brought the boat around & started in. I explained to my guest the situation, then the rpms started dropping off.. until the engine stopped.. I noticed some steam/white smoke now coming out of the cover.. I pulled the cover, the engine was felt really hot. The engine never seized, I could crank it over the whole time. I set my anchor & called a friend for a tow..The the rain started..
Once I was back at the house, I was able to start the engine on the muffs. As I walked around back, I saw steam, which I assumed was the rain steaming off, but then I saw bubbles from the back side of the port head, near the exhaust!
I ran for the ignition switch & shut it down.. I hosed the rest of the boat off, packed up my electronics, then hit the fridge for a brew! I need it..
Where do I start?
Where do I start?
