Gas tank full of rust! help?
DDanhour727
I recently bought my first boat and one of the many problems is my gas tank under the floor board has rust and water in it, how do I clean that out?
rbh
Re: Gas tank full of rust! help?
I would start by seeing how much rust you have,
if it is just rusty water and no big flakes, remove, empty, flush, swish some new oil around for a coating and away you go after you replace all your filters and clean the carb.
If you have big flakes coming out, its time to replace.
rob
WAVENBYE2
Have you tried a hand pump to pump it out>
Lion hunter
How difficult is the tank to remove? If you can get it out there is a product called Kreem thats used to recoat the inside of tanks. Used on old motorcycles all the time.
Lion hunter
Looks to do the same thing except kreem is a 2 part system. The 1st part removes rust and etches and the second part coats.
