1992 140 Evinrude V4 looper. Almost no spark on any cylinder. fired it up, it idled for about 45 seconds and died. wouldn't restart. hooked up a spark tester and it doesn't spark except for one flash every once in a while. While it was idling the tach was showing 4k which is obviously wrong.
i thought it was the power pack but i replaced it and it didnt fix it. it cant be the coils as all cylinders act the same. its not the ignition switch or stop switch because i tested that and got the same results. its not the SLOW function either as i tested it too.
FWIW i dont know what it is but the little module under the power pack was recently replaced but i dont know what that does.
the only thing i havn't tested is the stator, sensor coils and charge coils. i dont know which would have symptoms like these.
