So I starteed pumping out my gas tank.... Look what I found
JustJason
Re: So I starteed pumping out my gas tank.... Look what I found
looks like beer :)
krisnowicki
so wadda think bad tank or just really old gas?
rbh
looks like its time to clean the tank,
nice to see that the filter really works good.:)
rob
Bt Doctur
That appears to be "ethanol phase seperation" Need to drain and clean the tank, hoses, lines, carb.
KRH1326
Why is it that when we are surprised and "find something" is it usually a bad thing? Why not pearls or diamonds, or someone tried to hide 100 dollar bills in here?
krisnowicki
then engine is running tip top on a fresh tank ... I havent used this tank because of this problem. I am in the middle of pumping it all out just trying to figure out if i can clean and keep this tank of if I should just by another
KRH1326
How big is the tank, and how hard to get to?
krisnowicki
62 gallons and I can get to the end of it with the sender and fittings but taking it out will require engine removal and some cutting of the deck. but I can put a 30 gallon tank on top of it if needed.
KRH1326
I have a 62 gal. as well, but if I had to pull it, I have the room. I had a problem when I started this restore project. The old fuel fill hose had disintegrated and all of the "crumbs" went into the tank. I can't tell you all of the havoc that wreaked.
ANYWAY, I set up an electric fuel pump, but I mounted a heating oil strainer and a 100 micron filter inline with it. I drained the tank down, but not empty. Then I pulled through the sending unit hole, through strainer/ filter and dumped back through fill neck. I let it circulate almost all day, untill I wasn't getting any more debris. I kept moving my suction hose around in the tank like a shop vac.
Maybe this would work for you, substituting a seperator for the filter rig?
