CaptainZ55
Thread starter- Joined
- Jul 26, 2009
- 9
I have a Mercruiser 350 Magnum with a Rochester 4bbl carb - 1988 vintage. Last season the following started: after running the boat for a while (hot engine) we would turn off the boat and anchor/swim. When we tried to start the engine it would not except after many cranks with throttle in full position. When if finally started is was a sputtering stumbling process. Thought it was bad fuel as ethanol was added to fuel around this time. Drained fuel tank, replaced distributor sensor (Thunderbolt IV) very rusty, and cap and rotor, plugs, wires, and reset timing. Rebuilt carburetor two times with everything looking good. Engine runs great otherwise and will start right up when cold. Believe float setting is correct. Only way to start if warm is advance throttle (in neutral) to full position and the engine will eventually start albeit a stumbling start then have to pull back throttle quickly to prevent over rev. Engine has only 265 hours on it. Prior to this problem engine was rock solid with easy turnkey starts when warm, cold starts needed a couple of throttle pushes to inject some gas.
Any thoughts would help.
CaptainZ55
CaptainZ55
