is this boat over propped
180shabah
Re: is this boat over propped
and see how many turns i get to one revolution of the engine
OR, how many revolution of the engine to one turn of the prop...
hwsiii
Shabah, theoretically the prop will turn either 1.32 times or 1.5 times for each turn of the engine. LOL I don't make an error unless I breathe.
H
180shabah
Actually it is the other way around. 1.3-2 engine revolutions for a single prop revolution.
hwsiii
LMAOOOO Shabah I TOLD you I only messup when I am breathing. You are 100% RIGHT, thank you. MAJOR CRS
H
jaxnjil
hi guys thats for all the info
i will pull the spark plugs out at the weekend and see how many turns i get to one revolution of the engine , until then thanks to you all
ps the speed is gps but its exactly the same as the air intake speedo on the dash .
it might be easier to do 3 full engine revolutions and that should give you 2 perfect prop shaft rev. if is 1.5:1 which it should be
1.32:1 will go past 2 full revolution
the difference will be easier to see than trying to guess the how far the prop shaft turns for one rev of the motor
recoil
hi guys , might have found the problem why we have no bottom end grunt , it turns out the brother picked the wrong manifold the one that's on is a torka 2 edelbrock but the rev range is 3000 to 8000 rpm , so we intend on swapping the manifold to a performer rpm edelbrock , were its rated at idle to 5000 rpm this might give use the bottom end grunt were after , also having the engine dyno tested to see exactly what hp its producing ,
hwsiii
That makes excellent sense and please let us know the results.
H
recoil
now this is were i get a little lost , i think its the performer rpm , there also the reformer air flow , and just the performer , i think the one we want is the performer rpm , if any of you guys suggest any thing else i would consider it , also will we have to do some work on the carb its a quadrajet , or is there a better marine carb on the market , cheers guys
Apollo75
Hello;
From what I have read your boat is over propped. Your set-up is for high rpm horsepower and should turn a higher rpm under load.
Also, that manifold with the ported heads and cam? Marine --- what size? All of these will lower your low end torque, and torque is what launches a car or boat. Too bad you can't put a low stall torque converter in the boat :p
I would change the manifold to a lower rpm two plane design for low rpm torque and depending on the cam may have to advance the cam a couple of degrees. I think the increased compression from installing flat top pistons should make up for a lot in gearing, etc.
"Advancing the camshaft means that you are starting the opening and closing process sooner in the cycle. It generally improves low-speed torque and mid-range power while sacrificing top-end hp. "
www.carcraft.com/techarticles/116_0403_camshaft_basic/index.html
When you get the rpms correct and the low end torque you need --- consider playing with the carb. There are two sizes of Q_Jets 650 and 800 cfm. There is also many tricks to help those carbs perform great.
OFM
