gnarbrah
Thread starter- Joined
- Sep 20, 2007
- 140
Hi all - well I just got back from a week in the Keys and my 12' Carolina Skiff with the Johnson 20 did pretty well. The only complaint I have is that once I really got planed out and cruising the motor would sputter and die. I had 2 different tanks and hoses with primer bulb and the same thing happened with both setups. Once I got planed out I tried to pump the ball but I couldn't keep up and could never get it to harden up as it should. The tanks were vented (even cap off at times to be sure). I also rebuilt the carb a couple months ago and nothing but fresh gas through it since then. Running at low speeds was no problem at all and I could put around all day with no issues - only when it was wide open or anywhere close to it.
Bad fuel pump? Something else I should check?
Thanks!
Thanks!
