KWS3Robalo
- Joined
- Jul 27, 2009
- 1
I have a 1977 20' Robalo center console that needs a new transom.
Its in pretty good shape for its age. I purchased it form the original owner and it is pretty much completetly original. Even has the original twin 1977 85 hp Evinrudes with very low hours.
I have read several post on the subject of transom replacement but most detail cutting out the back and repairing the gelcoat. This has been good information but I would like to remove the deck and repair it from the inside.
So far, I have removed everything from the boat. Rub rail, bow rail, engines, all the wood, center console, all wire/cables, gas tank, etc. Everything!
This boat seems to have a lot of foam in it, which I am sure is holding the the deck and hull together. Before I started pulling, jacking and prying, I figured wouldn't hurt to ask if anyone has any advice, which will keep me from damaging anything. Also, does anyone know if the manufacture glued or glassed the hull and deck together?
Thank you.
KWS3
Thank you.
KWS3
