Volvo 4.3GL - What is the engine code?
swcolorado
I have a 2001 Reinell with a Volvo Penta 4.3GL PEFS.
The drive is a SX-M 1.79.
What is the last letter I should be using to order parts.
I come across different suffixes after the 4.3GL. For instance: 4.3GL-A,B,C,D etc.
I can't seem to figure out the difference.
Any idea which letter I should be using to order parts?
spktho
Re: Volvo 4.3GL - What is the engine code?
It should give you the engine model on the flame arrestor on top of the carb.
Don S
You have a 2001 boat, with a 2000 engine package. Your engine is painted gray. not red. Click on the link below.
http://www.volvopentastore.com/Gaso...*****.432302572--store_id.366--view_id.342338
Anyway, the EF in your model number is what determines the year. Using weird letters was the last of the OMC era. In 2001, Volvo went to a Volvo method of ID. A is an older model than B, and C is newer than B. What a concept. There are also model changes that have nothing to do with year. That is why I always ask for model or SN. Year of the boat is a waste of time.
swcolorado
You are absolutely correct. The engine is charcoal so it is a 2000 vintage. Once I input the 2000 model year, the PEFS shows up.
Thank you.
