tilt and trim motor question
rockyman
1981 galaxy 165 hp L6 165 nerc outdrive, my problem is this,i took the cap off the tilt and trim motor by mistake . underneath of this cap it has two springs and two bushing that goes over the copper peice [i dont know what it is called ] that sits about 1 inch down the motor spindle. i hope this makes sense to someone . how do i get the cap back on ,i know you have to depress the springs somehow, but what is the trick to that . thanks
Bt Doctur
Re: tilt and trim motor question
You can try installing the brushes and holding them inplace with garbage ties, slide the cap over the armature, and release the ties.
rockyman
thanks boatdoctor , i didnot expect anyone to understand what the heck i was talking about lol . thanks again , george
cr2k
If you are lucky you can pull the armature and housing out without loosing the coupling on the other end. put the springs and brushes back on on the bench using small screwdriver or other small tool to hold the brushes or dental floss that you can just slip out. Make a tool form a small piece of sheet metal with a slot in it just large enough to clear the shaft. put it on bottom end to hold armature in place put back on res. and slide out the plate. (Basic instruction) You need to line up the coupler etc.
In other words, if you have to ask how to get it back together, you shouldn't have taken it apart, but hey this is how we learn.
Yes it is a pain in the butt to put back together.
