90HP Johnson Outboard. I noticed that someone changed the coils to a newer style coil; it is supposed to have coil with 2 wires coming out of the back and the single spark plug wire going to the spark plug. But it has coils with a spark plug wire going to the spark plug and then another spark plug looking wire going to the power packs and then a ground wire attached to the mounting bolts. I am only asking because I have a slight miss and was thinking maybe they do not put out the same voltage as the ones recommended for my particular motor. I have referenced the coils that are being used as the coils used on a 1986 90hp model Johnson. Are they the same with the exception of the wire connections?
