FBPirate95
Thread starter- Joined
- Apr 15, 2009
- 840
I've already talked to TD about this, but I want to check with everyone to see if they have had the same experience.
The other day, my wife and I went out on the boat. When we cleared the no wake zone I opened up on the throttle and the motor stalled and shut down. I checked the primer bulb and it was soft. I reprimed it and started right back up. When I tried to open up again, the same thing happened. We wanted to fish so we just decided to cruise to a spot at idle speed. We fished for a while and when we started home, we had the same problem. I had my wife pump the primer every so often, and we made it back to the dock at low speed without the motor shutting down.
I'm assuming I either have a air leak, or bulb issue, or a bad fuel pump. Before I spend the money and replace the pump, is there anything else I can check to make sure its not something simple?
I will say I did go out today and primed the bulb. A couple minutes later the bulb had softened without me running the motor. Don't know if that tells me anything....just added info.
Any ideas will be appreciated.
