Changing Gear Ratio
Blujay96
I have a 1987 Alpha One drive with a 3.0 4cyl. 130 hp. It has a 1.98 ratio drive on it. I need to replace the drive. Is there any other gear ratio's I could go with that would preform good with the 4cyl without working it to hard.
Blujay96
Re: Changing Gear Ratio
Thanks for the insight mkast
wca_tim
the 4 cylinder already comes with the highest gear ratio (making more torque at the propshaft than the lower ratios) and so your factory ratio is right where you need to be.
Blujay96
Thank you I will stick with the 1.98 then.
