Is this supposed to be like this?
KaiBlaed
I recently almost lost my motor, which tore up the fiberglass on the transom a little bit. I took off the aluminum molding from the top of the transom, and discovered that there was a gap between the fiberglass which left the wood showing on the back top corner of the transom. It's a 1967 Starcraft, the wood doesn't look bad, should I seal the aluminum strip that covers it? .. or fiberglass it closed?
Thad
Re: Is this supposed to be like this?
I'm no expert, but I am pretty sure that exposed wood is BAAAADDDDD!
pduquette
Ensign
Weclcome kiaBlaed ! Ah , if the transom ain't rock solid it needs to be !! Investigate further - the flaws should show up rather quick ! Now how did the motor turn out ??? peter
KaiBlaed
I recently went to much larger size cables for the steering, which did not have a problem holding the motor up out of the water. So the motor is still in good shape.
