Re: How do you bleed power trim/tilt 2001 90hp
The plastic cap in the front is for filling the reservoir. When the engine is fully in the raised position the oil is all in the hydralic ram. When its lowered the oil is in the reservoir and might have pressure. Inside the reservoir is the pump that is driven by the T&T motor. Underneath the TT motor probably on the right side is another plastic screw. There should be access through a hole in the motor mount. Releasing that screw will drop your engine without power. Or basically free the ram so you can move the engine freely.
