Hey guys. I have a question regarding my 1985 Force 85hp. It is the 3-carb, distributerless ignition model w/3 coil packs. I purchased this boat (1992 capri) as a project and I havent had it on the water yet.
My issue is: I can start the engine and it runs (by my ear I am thinking about 400-500rpm) (so pretty low) when the Idle is advanced by placing the shifter in neutral and fully advancing it. After 2 mins of warming up I begin to back off the throttle to center neutral position and as I move it back the rpms drop and the engine dies about 1/2 way travel between full advance and center neutral.
I am an auto mechanic by trade, so I figured this would be no problem but I fully admit when I know nothing about what I am dealing with and I've never worked on outboards before. I have a shop manual for the engine.
This is what I know:
The compression is good.
There are three brand new plugs of the correct type (ngk buhx installed).
Fresh pre-mix 50:1 fuel is in the tank.
All carbs are completely clean, no needles are stuck. Idle mix screws (located on the front of the carbs and behind the rubber grommets in the intake manifold) are set at 7/8 turns out from a light seat as per the initial adjustment specs.
I have correctly adjusted the choke plates and solenoid as well as the throttle plate linkages.
The mark on the throttle cam is lined up exactly with the center of the plastic roller attached to the carb linkage when the throttle is in center neutral.
There is no contaminants in the tank, the fuel screen is completely clean and no obstructions such as in-line fuel filters are installed. (once i get it running correctly I will install one).
The only thing I havent checked so far is ignition timing. It is very odd though because this doesnt seem to be behaving like a timing issue. Most of the hondas I work on will idle in neutral even with timing fully retarded or advanced. I will check the timing when I grab my light from work. Can I just ground the plugs and leave the prop on the engine to check it? I assume the manual says remove the prop for safety reasons moreso than actual performance.
Any help would be appreciated, I really dont want to have to spend money to get this figured out.
