greatoutdoors
Thread starter- Joined
- May 2, 2009
- 116
So, I have done a carb kit, new plugs, new coils, cleaned and gapped points correctly, compression seems good. Ordered new points and condensers just so it's all new. Still can't get it to stay running. Will fire after about ten hard pulls, runs smoothly for about 5-10 seconds, then dies out. Fuel and air lines and tank are good, I use them on my other motor which runs perfectly. What is wrong? The high and low speed needles seem worn and loose. Will this cause this problem? If so where can I find them? I'm getting gas in the carb bowl, so I'm stumped at this point. Does this motor have timing? How do I adjust it correctly if it does? Please help and thank you in advance.
