May be a long shot, but any chance mercruiser risers bolt to PCM manifolds?
mylesm260
I don't know if any of you have experience with mixing and matching manifolds/risers,
But will a mercruiser riser work with a PCM manifold?
PCM engines are typically for inboards, not inboard/outboards.
Their manifolds look very much like mercruisers, and their risers bolt on in a very similar fashion.
http://www.pcmengines.com/engines.php
PCM is selling their LY6 manifolds for 225 bucks each!
Re: May be a long shot, but any chance mercruiser risers bolt to PCM manifolds?
I seriously doubt it...You might want to call them and ask.. I would just get the risers from them to have a good match..
good luck!
mylesm260
I would, except their risers have a different bend and length on the outlet, doesn't look like it would match up to the mercruiser Y-pipe....
I could always fab up adapter plates, to make the mercruiser risers work, and they would also double as riser extensions.....
