'64 Starflite 75hp Woes
OldWoodBoat
Hello folks. Was referred here from another site because of the knowledge base here. I'm having a problem (or set of problems, seems to be never ending...) with my '64 Starflite. It's a 75hp, with the battery/CDI ignition (no magneto).
The problem I'm having is I'm getting no power through the junction box to the starter. Well, let me back up a bit.
The boat has sat for a long time - I just got it back from my brother in law last fall. He had it for about 7 years, used it once. I tried tank testing it last week after obtaining a new cylinder head (found out the threads on #4 cylinder were stripped when I pulled the plugs to check their condition) and discovered that nothing happened when I turned the key. Here's where the fun begins.
I decided to try arcing the solenoid to start it, like you might try on an old Ford van. The starter cranked for all of about a second then went silent. That was a mistake - if the solenoid wasn't shot before it certainly was after that little stunt. I also burned out the voltage regulator, the condenser inside the junction box, and two 40 amp fuses.
So I buy a new solenoid, new voltage regulator (Neihoff replacement for the Delco-Remy part that was in the junction box), replace the burned fuses, and found a replacement condenser from a local boat dealer.
I've gone through the junction box at least two dozen times so far checking every wire, every connection, every fuse, rechecked the fuse in the dash, tested the ignition switch, tested the new solenoid, tested the starter itself -- but I still get nothing going to the starter when I turn the key.
I've gone over the test proceedures and wiring diagrams in the shop manual a dozen times so far, only to keep beating my head against the wall on this thing.
The starter I know still has life - tap the positive terminal with a set of jumper cables and she cranks. Nothing else even makes her do that. The only thing that happens when I turn the key right now is the automatic choke engaging. Nothing else is going on.
I'm stumped. I can't spare the cash to take this to a marine mechanic - hell it'd cost more in their labor time getting it running than the engine is actually worth - and a new motor is also not in the cards any time soon. This is a mandatory DIY project for me.
I really was hoping to get this thing running so I might be able to get the boat on the water at least a couple times this year, and get my dad out fishing - it's been ten years since we've gone fishing together. He built this boat himself back in '85.
When this motor ran, it ran fine. Always had a little trouble with the carb adjustments, and it never ran terribly well at high altitudes, but it was a 20+ year old engine when we got it 23 years ago. I'd like to make the beast live again.
Advice on getting this thing back in running (or at least cranking) condition would be much appreciated.
~Mark
OldWoodBoat
Re: '64 Starflite 75hp Woes
Yes. It never occurred to me though to double check that switch. Selector shows neutral, and I've gone through the gears with the key on (although I'm not sure she'd shift gears without the engine actually running) but have not actually inspected the neutral safety switch. Guess that's my next step. Hopefully it's a part I can still get my hands on if it's shot. Gotta "love" vintage outboards.
Thanks for pointing out the NSS idea. I'll post the results of that test...
Joe Reeves
The ignition on that model is "Automotive Ignition", not CDI (Capacitance Discharge Ignition-Solid State).
Merely jumping the two large solenoid terminals to bypass it should have no effect on other components...... blowing fuses, etc. Was there something else done to cause that damage?
The neutral safety switch on that model is normally located at the distributor. Too much throttle appplied disconnects the ground, via that switch, from the starter solenoid, effectively eliminating that circuit.
Willyclay
I had a similar problem on my 1962 Johnson 75HP with the distributor ignition system. Finally determined the in-line 20AMP fuseholder, not the fuse, was defective. It checked okay for continuity but would not allow the proper voltage to pass due to corrosion in the connections. Replaced the fuseholder and the motor started/ran. It continued to serve our family well for many years. Good luck with getting your dad back out in the boat he built.
cougar1985
also check the cables very carefully.after 40 odd years they may have gone green.had a 65 merc that was giving me fits and when i peeled the pos and neg cables they were green and white powder and toast!
