Hello everyone! and thanks in advance for your responses.
The compression is close to 80 on both cyl.
The carb was taken apart cleaned with solvent and blown dry with compressed air.
The ignition has to be in great shape since after 20 pulls as long as I don't let it idle to slow runs well. It does have hesitations when I open her up very quickly almost like it's not getting enough gas. Not really sure if this is also the same reason for the hard starting.
Yes I have adjusted the idle screw
But as long as I don't let it idle to slow everything else is smooth, even the top end is very strong.
Runs like a top so I'm out of ideas as to what the problem can be.
The only thing I can think of is maybe the reeds are not sealing properly?
Thanks all.
Thanks all.
