ScottinAZ
- Joined
- Jun 25, 2009
- 831
I would like to get a reality check here that the prop that I have is the right one for the boat, I think it is, but would prefer to know that I am not running with excessive slip, or just wasting gas.
Boat is a 1982 Imperial deep v (V183) with a 1982 Evinrude 115 outboard on it. I was running it today, and got up to 36.5mph according to GPS. (pitot speeds correlated nicely)
Specs on the boat are as follows
WOT MAX 5500RPM
1150 empty weight
~150 lbs of misc gear (anchor, PFD's, Battery, misc "junk in the trunk")
20 gal gas (give or take a gal or so)
300 lb Me
prop is a Solas 13.25x17
At 4500 rpm I was running at 30mph, give or take. all other specs are the same
I do not know the specs on the engine gear ratio, nor do I know the deadrise angle on the hull (I dont even know how to check the deadrise, but I could check it if explained how)
WOT MAX 5500RPM
1150 empty weight
300 lb Me
