Re: Shift Cam position???!!!Please help
so the schematic is on the cam: high side-reverse..... medium side-neutral...... low side-forward so maybe the easiest way about going about this, is find out which way the shift shaft it turned when shifted into forward, and reverse, then have your shift rod positioned in the middle (neutral) then depending on your knowledge of which gear turns which way with the shift shaft you should know how to position your shift cam.... example, say you have your shift rod and you have a point indicating its position at 12 oclock, and this is neutral so right now the medium side of the shift cam should be touching the shift cam follower, say when you shift into reverse it turns the dial on your shift rod clockwise to 3 oclock, then we know if we turn it this way, the high side of the shift cam now must be touching the shift cam follower, then to get into forward, we would shift back to neutral and your dial will be back at 12 oclock, and then we go counter clockwise to 9 oclock and now your shift cam will have the low side in contact with the shift cam follower
what im trying to say is you have to figure out which way the shaft turns to engage forward and reverse, once you know this you will be able to adjust your shift cam accordingly.
