I have a 1990 stratos open bow with a 4.3. The boat was sitting for about 4 years due to a bad motor. I bought the boat and put a new long block in it .installed new fuel filter and drained all old gas out of it and took her out and ran great. Used the boat for several weekends and even pulled tubes with no power problems.
Now all of a sudden it starts to bog down like its running out of fuel and then goes and bogs and keeps doing this. It idels great and is fine at 1000 to about 1500 rpm and anything above that the problem starts. It seemed like a fuel problem so I changed the fuel filter and took it out and same thing. Replaced the fuel pump, same thing. I had a new set of points and condenser so I put them in, same problem./ Its like its running out of fuel and then picks up and rpm just keeps going up and down. It seems like the problem started after I was out on the lake when the lake was real rough and the boat was hitting the water pretty hard. Could this be a fuel tank pick up problem ???
I think tomorrow Im going to take a fuel hose and put it into a gas can and run it off the gas can to see if this fixes the problem. If not, where do I start next. Like I said it idels fine and runs up to about 1500 rmp fine so I dont think its the interuper switch ????? Any thoughts would be great and thanks in advance
