Re: '90 90 hp Still having problems!
What is the condition of the boat like? Any water in the bilge? Rebuilt floor....or poor floor condition?
If your boat has a lot of additional weight because of water in the bilge or absorbed water into the hull foam and wet/rotten stringers etc you might be trying to plane a 2000+lb boat instead of a 1400lb boat.
If the boat is usually trailered try to get a weight off a local scale the next time you are out and you can rule that out of the equation.
Note: I've got the exact same motor/boat set-up with very similar compression and with a 17pitch prop. It gets up and goes reasonably well for a 19 year old boat/motor.
(speed: high 30's to maybe 40mph, with revs at approx. 5400-5500rpm)
As John said, go through the timing procedure. As well, make sure your throttle/carbs are opening up fully. If they linkage is out of adjustment you might only be pushing 3/4 throttle (or less).
I believe the manual covers this procedure and check.
Good Luck.
BP
