1) Performance issue you are trying to correct.
RPM to low - 4800
2) Current prop manufacturer, model, aluminum or stainless and as a minimum.
SS - second hand manufacturer/model not known
3) Current prop diameter and pitch (required).
17
4) Wide open throttle RPM and speed with an average load (very helpful)
4800 @ 30mph GPS
5) Engine/drive make, model, year, and HP
40 E-Tec 2007
6) Boat make model, year, length and weight
Southfork, 2007, 15', 800lbs?? 1200 loaded??
I bought this second hand. Motor has very few hours on it. Boat rated for 30hp. The prop is second hand and had been worked. Prop calculators would suggest that the prop is actually at 19 pitch. Motor is on a CMC PT-130 tilt and trim with a 6" setback. Motor is about 1" above the bottom of the boat.
Suggestions??? Lower pitch?? Raise Motor??
Thanks in advanvce.
RPM to low - 4800
17
4800 @ 30mph GPS
40 E-Tec 2007
Thanks in advanvce.
