Re: bearings tolerance
you will always have slight play side to side. The top bearing is a roller bearing (expensive). You will likely never wear it out unless you run without oil or overheat the engine.
Up and down play is determined by a ball bearing at the bottom of the crankcase. You will always have slight play here as well, but will slowly progress as this bearing wears from useage and rust.
