nola mike
Thread starter- Joined
- Apr 22, 2009
- 6,099
Sorry in advance. Since I know this info is on here somewhere--i'm on a blackberry and am having a tough time with searching...
Anyway, merc 170. Noticed a bit ago that overflow level was low on coolant. Refilled last week, and after some fairly hard running noticed that the overflow was again low, and coolant had overflowed through the reservoir cap. Coolant level in the reservoir was fine. No overheating. I did a compression test about 2 mos ago, and all 4 were 165 psi. Today I did a coolant pressure test, and it held at 17 psi after tightening a couple of hose clamps. Cap was a little low at 10 psi, but I doubt that's the prob. Refilled everything, ran on muffs for 15 min and noticed a bit of white smoke coming from gasket between engine and exhaust manifold @ #4 cylinder. Now, I know that these engines leak into #4 because of a failed...something. But I don't remember what. Gasket between riser and manifold maybe? Anyway, could this be the cause of my symptoms, or could this still be something more serious like a headgasket or warped/cracked head?
