1965 **** Schuster 18 foot Runabout **NEW PICS UPDATED 8/23**
kibs45
I have been snooping for a while and have really enjoyed what I have seen. I just thought I would share what ended up in my driveway today! Its a 1965 **** Schuster 18 ft fiberglass. I havn't been able to find much on it, but it seems to be a very quality boat (if a bit neglected). Anyway I will try to document what all happens to the boat, but I am not a real hurry so I can't promise it will happen quickly. First things first though, any suggestions on a good cleaner/sealer for the outside? By the way I can't seem to find much about this **** Schuster, anything anyone might know would be great.
kibs45
Re: Quick Hi!
Re: Quick Hi!
Well I guess Picasa is being difficult, heres the link to the album... Sorry about the empty posts.
Lightnig
Re: Quick Hi!
Re: Quick Hi!
Actually a good looking boat you got there, I quite like it.
Well, it will be once it gets all cleaned up and fixed up.
And here, I'll get those pics posted up for you.
I just copied the image address and wrapped that in [ img] [ /img] tags... ;)
kibs45
Re: Quick Hi!
Re: Quick Hi!
I tried and tried but just couldn't get it right, ie the blank posts. I think thats the code I was using, maybe the link was wrong. Well I have started the process of cleaning the inside of the boat, and its incredible how much that helps. Soon enough we'll clean the outside, and get the engine/outdrive dialed in. I am very excited as this is my first boat, and it seems like it will go together nicely. Probably just a lot of work! Anyway thanks for fixing that and like I said if anybody knows anything about **** Schuster I am always curious...
ezmobee
Re: Quick Hi!
Re: Quick Hi!
Very cool old boat. Good luck with your (very large) project!
Lightnig
Re: Quick Hi!
Re: Quick Hi!
your picture link should look just like this (with no spaces though...)
[ img]http://lh6.ggpht.com/_hApPgBQ8dxI/SnUKs1xN1mI/AAAAAAAAAKI/6VdLAKLK1l4/s800/DSCF4804.JPG[ /img]
keep trying, you'll figure it out in no time :)
if it's just clean up, re cover the seats, and go through the drive unit, it won't be bad at all. If you are needing floor and transom, then it will be a big project indeed.
Looking forward to seeing more pics once you get those years of gunk cleaned away...
kibs45
Re: Quick Hi!
Re: Quick Hi!
It seems like i am going to be very lucky with the floor, I highly doubt so lucky with the transom though. However when a buddy says "You're looking for a boat? Get mine out of the yard." You end up with what you end up with. The floor is very deep into the boat, I think you can see that in a few of the pictures, and looks molded as opposed to fiberglass covered plywood, but I just don't know yet. I am slowly but surely getting it cleaned out, and then on to the motor before the "deep cleaning".
Lightnig
Re: Quick Hi!
Re: Quick Hi!
Hard to tell from these pics, once you get it all cleaned out of leaves and branches, take a couple of pics focusing on the floor and we'll have a much better idea.
But, looking close at the floor in front of the rear seat, it looks to me like the floor is wood...
tlovelandka
Re: Quick Hi!
Re: Quick Hi!
Very cool boat indeed! Good luck with your project...:D
-TLove
kibs45
Updates after doing some cleaning...
So I started getting things cleaned/tore down today, and I am very encouraged by what I have found. I think I need to get the transom cap off to see what all is going on back there. The floor is absolutely solid, and the only wood I see near the transom is not actually attached to the transom its about 6-8 inches away. I am posting some more pics any thoughts are always appreciated. A bunch of the wood for the seat supports is rotted as well as the wood near the transom. Those look easy enough to remake. I still surprised by how well the floor seems to be holding up. I think it is wood though because in one of the pictures you can see what looks like minor cracking. Other than cleaning out some more nastiness and taking care of the engine I think it won't be too long before it starts going back together.
Thanks Joel
kibs45
Re: 1965 **** Schuster 18 foot Runabout
kibs45
kibs45
Alright got the stupid pic thing figured out! I was taking another look at some of the stuff today, and here are some more thoughts. The tank in the bow is probably an add on, and I don't think the barrier between that space and the seats is original, especially the two boxes. I am also wondering if the wood that creates the "space" behind the rear seats and the actual transom is also an add on. I have resigned myself to pulling at least the transom cap off to see whats going on in there. All the fuel line work is very shotty. It will all need to be redone. I need to finish cleaning out the inside, I am going to rip out the seat bases and make new ones, I also kept the seats because the hardware is all good, I can use them as templates to make new ones. I am also going to remake the "shelf" that runs along both sides. The very next step though is going to be getting the engine/outdrive tested out. Anyway thats the progress so far.
Lightnig
looking better now. :)
I must say, I've seen a lot worse floors than that one is. Just keep pulling out the bad until there's nothing but good left, and start putting it back together. This project may not be as in depth as many are.
robbankston
Re: 1965 **** Schuster 18 foot Runabout **NEW PICS UPDATED 8/17**
Cool old boat.
THEPATRIOT
That's a sharp looking boat!I'm very happy to see all these vintage boats being saved :).
