whitesnreds
- Joined
- Aug 2, 2009
- 6
ok 1985 evinrude 150xpwill not stay on. It turns over then starts running for a second then shuts off. seems like its not getting enough gas. The outboard was sunk then dried out and all the water was taken out of cylinders and fresh gas/oil was added along with gas treatment . Also Whenever i push in the choke to start it gas comes out of carb. Is that normal? Its my very first boat. Need help. I know the engine is not ruined because it will crank but then dies immediately. carb problem? gas pump or line problem? gasket problem? air? water or dirrt inside some filter? I dont know but im hoping on you may know. thanks. Next step is getting a mechanic out to it.
