questions about new steering cable
escapade
So I measured my steering cable and needed to order a 12ft cable, so I did such, it came in on friday however its quite a bit longer then the orignal cable but only on the black cored spiral part the sheth is perfectly matched, does this make a differance should it be cut to fit? or is the cable actually too long??
also the motor mount ends are different, the orignal cable has a threaded end and the replacment does not? do these ends just screw off? or do I have to modifiy how the cable mounts to the motor???
Re: questions about new steering cable
ends are pressed on. what motor are you using. never seen one with the threads.
escapade
its an 80's 70HP merc 3 cyl I'll have to check on the motor to see if I can remove the threaded adaptor, and put the bolt directly through the 'eye' on the new cable,
escapade
below are the pictures of the connection at the motor, and how it connected to the older cable, its kinda like a universal joint/hime-joint however the bolt that does go thought it will connect to the new cable just not the special end piece.
escapade
what do you think about the cable TD??
