Replacement for OMC Cobra
CCman1
I have a 1994 19' Chris Craft Concept with a OMC 5.0 Litre(Ford) mated to a OMC Cobra outdrive. Is there a non-OMC sterndrive that I can replace my current OMC unit with? I really like the boat and I would prefer to replace the sterndrive with a more reliable one if a replacment is possible without major rework?
dubs283
Re: Replacement for OMC Cobra
not sure of aftermarket OMC drives
that era circa 1994, you could have a Volvo SX drive that has the OMC name on it
if so you could go with a new Volvo SX drive, but it is exactly the same as the OMC of that vintage
danond
Mercruiser Alpha One drive systems use the same transom hole and engine mount dimensions, but you have to remove EVERYTHING OMC. Controls, transom plate, exhaust, throttle brackets, wiring harness, drive.
What you're talking about is much easier accomplished by selling the boat and buying one with a different drive.
OMC drives are reliable when they're adjusted properly. Get a service manual, get it adjusted, and enjoy it until you sell it.
If you have a 94 OMC drive with the cone clutch, you basically have the OMC/Volvo joint venture drive which is better than any Mercruiser. Where is your raw water pump located or, better yet, what is your model number?
CCman1
The Model number of my OMC Cobra Sterdrive is 987346.
Don S
That is a 1993 Cobra drive, not an SX Cobra
CCman1
Yep, I know it is a Cobra sterndrive and not a SX. One of the replies to my original question mentioned SX in his reply.
