1978 Newman 18' Pla-Ville bowrider restoration project pix and costs associated
bigredinohio
Re: 1978 Newman 18' Pla-Ville bowrider restoration project pix and costs associated
I don't know how I've missed this thread but it looks like you're doing a pretty good job. Can't wait to see the finished project.
Nothing better then seeing the whole family involved with a project like this and see the little one smiling really big.
vegasphotoman
Thanks Big REd Ohio
Wish we had more TIME to work on stuff.........uuuhg...having a ball with it though....neeed more $$$ too hahahha
We should be doing more work on it either later tonight or tuesday possibly!
ps just ready your thread, SWEET job on the Checkmate!!!!!!!!!
jcsercsa
YEp Vegas LOOKS Great !! really nice work !! are you going to paint her also ?? John
HVAC Cruiser
Looking good Vagas keep up the great work. Two projects at once, I had been caught up following Jezabel didn't realize you had this one going too
I agree, I wish wifey got involved with my project bUt she just walks in shakes her head says im crazy out of my mind and walks out
adijoseph
You are a life saver going over your entire resto. As soon as our boat gets back from having the engine gone over I need to redo it's floor. I've been stressing over it since we got the boat ('72 Grady-White Sportsman). It's the same shade of green as yours. You've got to love the 70's :D.
vegasphotoman
Hi John, yes..we're painting part of the ship.... house of kolors sunset orange pearl see image--- on the top, above the bump strip, automotive HOK clear coat over that (sprayed) going to attempt GEL COATING = white on the bottom, we want to do it the best possible...if we're going to restore a bunch of boats we want to know how to do gel coats...so why not do it on the first resto! lol I pray it goes well! might have to buy a gel coat spray gun...got a real good paint hvlp gun and a cheap Harbor freight suction paint sprayer...one of em may work...might need a bigger orifice for em...
Hi Hvac......yup we're nuts...and yup, and I'm sure lucky I married a truck drivers daughter from pennsylvania coal town...she's a worker! thanks for posting! and reading both posts. It's alot of doing at once...uhg...is all I have to say...
Hi Joseph....no problem...and thanks....and the 70s UUUUHG what was with the GREEN FETISH?:eek: couches, carpet, cars...dang...everything was olive army colored! lol.......it is alot of work...from the start I thought, FAST AND EASY....couple days...NOT lol :eek:
But it's do-able...Here's a bit of advice ....buy LOTS of resin, dip your brushes in acetone between bowls of resin mixes..as you'll probably do more than one bowl in a session...I use 18oz and 24oz dixie type bowls..they hold up great, add some acetone and mush the brushes around in between bowl mixes, cheap brushes...sometimes foam rollers but they definetly dont last and are pricey...used em for the top of the deck, made for NICE and smooth layout of resin..just dumped it on and rollered it...added a smidge of acetone to thin down the mix a little help soak it thru the fiberglass cloth etc......buy LOTS of resin cant state that enough......any brand of nitrile gloves in the 100 pack, they dont disintegrate in acetone like the cheap latex rubber gloves...measure twice cut once......Im sure your boat is a bit different than mine, theres lots of other great threads that go over the process, Im just doing it a bit faster....:)
Ill have to search out your post/s to check out your resto.......
vegasphotoman
Temporary hold on this project...Project Jezabel 23' ft sleek boat work is in full swing! we're on a roll!
We will be back on the Newman work :p SOOOOOOOON
thanks all! :D
racinrc14
Vegas, sheez, would you finish that Sleek already!?! Your Newman's getting lonely with that other boat getting all the attention!
Just wanted to keep the thread alive so it would be easy to find when you get back on it....hint hint.......;)
vegasphotoman
hha haha thanks Racin
speaking of you what have you gotten done so far on your project? havent seen any updates? just wonderin!
lol
ps sleek will be done super soon! weather is way cool this week....85 for a high....looks like the hot days of summer are over....we needed to wait for the next stage on the Newman...PAINT!!!!!!!!!!!!!! we need it to be cooler out....no wind....etc here's a color chip of the top half...you cant see the pearlescence/metallic in the color chip...trust me its awsome in the sun! go look at a new lamborghini! they use the exact paint...so do many many custom cars
Here's the new seats in case someone hasnt seen em
- photo is copyrighted by the respective photographer..
Did get ALOT of wet sanding of the hull done...thanks to my wonderful wife! She did 70% already...with her help we'll wrap that up...get the paint & clear-coat on..
then on to finializing the engine work.....installing the engine
install the carpet and seats....new stereo and hopefully (I want em bad) new white faced gauges....
already got the new bimini top ready to install....
also have to go thru the outdrive and install new water pump impeller and seals etc....maintenance...lube and such should go pretty quick once we're back on it.
CHEERS!
ps here's the motor currently in the garage....still gotta yank the pan replace rear main seal, check bearings...clean out pan, replace oil...install new starter... test run....
racinrc14
lol
Yeah, I know. We put the motor in late spring and ran the boat all summer. The plan is too start tearing it apart maybe as early as November. I know she needs a new deck, and likely strings, too. I'll core check the transom, but I believe it is solid. I'll start a thread when we commence the deconstruction.
Your interior is going to be really nice. White face guages would set it off. You can get all the guages at the 'Zone' except for the speedo and trim, and they are pretty inexpensive. I have looked at them, and they aren't too bad. Getting a proper speedo to match them would be the trick. I want the white face guages eventually, also. My plan is too get the smaller guages (temp, oil press, and boost:eek:) at the 'zone', and then get the larger Speedo and Tach guages from Iboats, so they would match. Make sense?
TojosMojo
Vegas, that's gonna be a great color combo... The only problem your going to have is deciding which boat to take to the lake :D:D:D
HVAC Cruiser
Your Newman project is looking great, love the color. the seats for some reason reminds me of my old Ricaro seats I loved them
BTW, played the song when I got home, my wife was rolling on the floor. She actually looked up the words to the song LOL
vegasphotoman
Song HERE
LOL awsome eh...loved that stepbrothers movie...that song was kinda Beastie Boys style...loved it....thanks on the seats....yeah they have some side support...they upholstery guy did just "ok" not super happy but it is what it is...Im learning upholstery so we can do it ourselves next project.....
hahhaha no sh%# ......now that the season is over here in Las Vegas we may be holding onto this boat till spring....we wouldnt mid atleast getting something for our $$ invest and time......as this is a "sell" boat...though Im sure we'll love the end result......Geez the paint ought to be woth thousands....prices have skyrocketed on good paint ....
Hi Racin
Im ordering mine (guages) from either Iboats or Basspro...they are 40% less than autozone...plus no tax! would be nice if there was a guage FACEPLATE replacemnt...that wasnt expensive...to just replace the faces.....the best way is screen printed plastic....hmmm....I took a spcreen printing class back in the day....gets me thinkin .........LOL...
about 1/2 way done on the Sleek projects sterndrive repairs....bought some supplies for painting the Newman OMC stringer drive... white.... and the same for the sleek (its a chrysler) and it is also white...any leftover paint will be used on trailers...... $300 for the painting supplies! OUCH will post pics when I get started stripping and painting the drive! should be VERY SOON
thrillhouse700
Wow that color looks great! So do the seats. Looking good.
mddubya
Hey Vegas, I had somehow missed the update with the seats and color chip. I love it, but then again, I'm a UT Volunteer fan. Yeah, I know, its going to be a long season it looks like.
Great work on both boats though.
I still can't subscribe to any threads though? No idea what I'm doing wrong?
system-f
does that stringer drive have the trim system that moves the trims the whole engine?
vegasphotoman
Hi System F
yes it does, heres how it works...the sterndrive part is on a pivot...it pivots abou 90% up and down..thats the LIFT motor.....it should be all the way down for fwd and back use....otherwise it will damage the BALL GEARS.....
the TRIM is hydraulic motor mounts that trim the drive up or down for planing and such...its kinda crazy but it works! I am not a fan however.....
theres LOTS of stringer drive boats here in vegas, for sale and such...
many people are scared of em...or what have ya....
They are easy to work on , the boot can be replaced using lots of soap without removing the drive part.....
I just down like a giant boot that could tear and leak..:eek:
vegasphotoman
Hi all Im hijacking my own thread!
well we took a couple days "break" on the Sleekcraft project..which is ALMOST done...close to splash time!
took a "break"....to work on the Glastron...........
we have to get our 1990 Glastron 175 Sierra cleaned up and prepped for a new owner!
SELLING IT...to many boats..seasons over.. ones gotta go!
posting this as a precurser to what we will be doing to the Newman's trailer...and yes it would be 100 times easier to paint a trailer with the boat OFF the trailer we'll be taking the newman down to the docks and leave her overnight in the water, so we can paint and maintain the trailer the right way...Lake Mead charges $20 per night (way too much I think)
this is what we did today and yesterday oct 8th and 9th........
Vacuumed, cleaned, painted all the window trim matte black (it was brassed in the edges) the wife scrubbed the carpet, armoralled the upholstry, removed all the stuff, damn I didnt know a little boat could hold so much clutter!!!!!!
It was like our garage!! lol about 100 life preservers, fishing gear, extra back up parts, snorkling gear...etc...kids junk for the beach yadda yadda
the trailer was knackered up....lots of rock chips LOTS of rock chips, faded paint, chipped and cracked pinstriping etc.....
washed all that down, scrubbed up the tires and rims, heat gunned the trailer pinstripe tape, scraped it all off, acetone removed the glue residue nicely.
Sanded the whoe trailer down with 240 grit sandpaper....used rust converter on all the visible rust, resanded those areas with 100 grit, then 400, applied glazing putty to all teh chipped areas, re sanded those with 100 to knock it down then 400, wiped the trailer down with degreaser wax remover H.E.T.
masked it all off (what a pain that was!) shot single stage, Urethane automotive acrylic paint...looks slick now! (got 1/2 painted, the rest should be done by tomorrow....)
Did a quickie touch up paint on the sterndrive mercruiser...all the paint was a bit faded...quick sand down to rough it up and a coat of auto acrylic gloss black
then on to a quick engine tune up and carb cleanout....check the timing....
the oil was recently changed so that's good to go.....rockin on!
heres a link to about 20 pics
jcsercsa
LOOKS Great there Vegas !!! want to do mine ?? I got to hit mine this winter !!! I am going to sand blast it then paint !!! John
vegasphotoman
Hi John
lol Sure Ill paint yours bring it by! shouldnt be but about $750 bux in gas round trip! :eek:
I hope you have a big compressor, sandblasting takes alot of air....
is your trailer all rusty?
--------------Newman Update----------
While I was dorking around with the Glastron trailer on Oct 9th, my wife finished up the wet sanding the hull on the Newman...and considering it's age (1978) there were only 2 gel coat cracks! She ground those out and down about 1/4 inch, shallow plate shaped grind out....and filled em in with fiberglass filler (the one with the little fiberglass hairs in it)
then she block sanded the repairs down....
just a bit more cleanup on it and we are ready for the Orange peal paint YEA!
http://lasvegaspix.com/projects/sleekcraft8/images/NewmalRepairs (3).jpg
gel crack all sanded and faired in
The wife isnt afraid to get dirty!
