merc i/o rough idle , stalled , wont start again
jpmay1
I have a 1992 maxum 1800sr mercruiser i/o 3.0L . The day before it ran fine pulled into dock added fuel cause it was t 1/4 tank. Next day I opened boat cover started it up and it idled rough for about 25 minutes then stalled. I tried to restart it wouldnt start. Its cranking but not starting. About a month ago I had to replace fuel pump so I also changed plugs and wires. There is no water seperator or fuel filter anywhere in sight. I looked all the way from carb to fuel tank nothing. I would really apprieciate any suggestions and advice.:confused:
1980Galaxy
Re: merc i/o rough idle , stalled , wont start again
should be a filter on the fuel pump. you gotta take off the screw on top and pop open the cover.
jpmay1
Is there usually a strainer on the fuel pickup inside the fuel tank? And is ther anything I can add to fuel in case of condesation?
