I have problem with motor shutting down whether at wot or just cruising. Had the little woman drive the boat while I squeezed primer bulb, and it never happened again as long as i kept squeezing bulb. So, I believe it is fuel related.
I have changed all fuel lines, added a fuel separtor filter, rebuilt carbs, and did away with oil side of VRO and went to premix.
The only thing I did not do was replace the pulse line or rebuild fuel side of Vro pump. I would say it would be the pump, just would like a second opinion.
One more thing, My volt meter on the dash and on my fish finder both go up in voltage when running, I have seen the voltage as high as 16.9 volts. Just wondering if this is normal.
Thanks for the information, This site has helped me a lot.
And the shipping on parts here have super fast and much appreciated.
