any ideas
barchetta95
had my 95 yamaha waverader ra700 out over weekend ran fine took out for last ride before heading home was running fine hit some waves then engine sounded loud with bad viberation when gave it throttle and not much powerany idea's thanks barchetta95
artificialreef
Re: any ideas
I did the same thing. Hit some chop then wouldnt move at all. Found out all my motor mounts broke off. Luckily the rubber coupler completely disengaged and didnt damage anything. Sounds like yours may be all busted up. Its toward the rear of the motor under a plastic cover and connects the shaft to the engine. Dont run it anymore until you inspect it. You could tear it up more.
